taskalfa 250ci black bacground
  • mrd1980
    facing porblem wit ta250ci black back ground in new m/c just run for30k i cleaned transfer belt & cleaning unit poblem re ocure in3k copy firmware virsion is v11
    • 23006
    How do the internal reports and test patterns look?
    If good, it's a scanner or calibration issue.
    If bad, it's engine related (developing, main charge)
    • mrd1980
      internal report is good, it is engine related but not sure whether it is of transfer cleaning section or belt
      volumn of m/c is high in 20 days 25k colour print has been taken
        • 23006
        Firstly, I'd look at sim U131, Auto. Any values varying from the target by more than 25 points indicate bad developer (usually overtoned, low readings).
        Also run sim U089, gray, test patterns. Any patterns repeating at 38mm indicate a dirty primary charge roller for that color.
        Between those two, accounts for most image quality issues. I know it's only 30K, but it could still be either one. =^..^=
