CANON iR4570 fixing alignment.
  • genx
    • Aug 2025
    hi everybody, I'm a new copiers technician and have big problem with CANON iR4570 fuser film damaged often times. I need fixing alignment such as pressure screw adjustment etc.
  • teckat
    • 16083
    Do not touch the screw pressure of the fixing assembly, cannot be adjusted in the field,
    u may need to replace the fixing assembly.
    Do not touch the screw used to keep the fixing assembly in place. Turning the screw will change the pressure of the fixing assembly, which cannot be adjusted in the field, necessitating the replacement of the fixing assembly.
    • genx
      re : CANON iR4570 fixing alignment.
      hi, teckat. Thanks for your advice but I attempted for many time changed heat roller and hi temp grease and it still happened.
      I need to know the adjustment method, tools or etc. Can you advice?
      • teckat
        • 16083
        There is no mechanical Adjustment/or Tools used to adjust pressure
        u may need to replace entire unit
        best bet is to get yourself a Service Manual
