waste toner container
  • bolabali
    • Feb 2011
    • 22
    i got "replace waste toner container" on iR3300. have tried clear counter few times but that message still there. however i can operate machine normally. what is possible error may caused? what should i do?
  • fixthecopier
    ALIEN OVERLORD
    • 4713
    You should empty or replace the waste toner collector.
      • 23008
      The message would suggest that, wouldn't it?
      The waste bottle is in an access door on the left side of the machine, toward the back, toward the bottom. You can just empty it. It uses weight, not any sort of optical sensor. And there is nothing to reset. =^..^=
      • bolabali
        • Feb 2011
        • 22
        That message appear after i emptying the bottle. I don't think have to replace the bottle with a new one, since it uses weight sensor.
