Ir5000 lcd blank
  • helleboys
    Ir5000 lcd blank
    no power and lcd is blank.... why?
  • charm5496
    • 2387
    so the green light on the control panel is OFF?
    Did you check your outlet, breaker on the machine, was the unit operational before you got to it? Need more information.
    • helleboys
      the green light on the control panel is on (green). lcd blank. machine cycle... but control panel not function
      • kuby
        • Oct 2007
        • 1408
        check and clean the control panel. Remove to clean and check the contact places for good connections. I had one do the same thing, turned out to be the control panel need a good cleaning. Also check the RAM, it could be bad.
        • krish
          • 16
          Boot Rom or SD ROM problem. check both.
          • charm5496
            • 2387
            BINGO!!!!
            • helleboys
              now the screen is on, but at the copy after 4-5 sheets of die screen again ... oh my god.. please help me...
              • charm5496
                • 2387
                first what did you replace....second where did you get the parts you did replace?
                I would double check the work you did and make sure all connections on the main controller are seated correctly.
