km bizhub c450 Image unit chip install
  • suresh
    • Jul 2025
    I got 4 chips to replace on the imaging unit of Konica minolta bizhub c450.
    I replace the cyan first, and no problem.
    I go to the Black, but the chip that came is different than the one on the imaging unit. The seller says its for C351 and C450. But the black chip is different.
    So maybe I have to order other chip. Some help here
    this is the image of what I got.
  • rosaro75
    • Mar 2009
    • 87
    if you need to reset the old chip pls send it to me and have to mention mc model 110v or 220v. send pm.
    • blazebusiness
      SanDiegoCopierRepair.com
      • 1250
      4chips-IU-KM-c450 | Flickr - Photo Sharing!
      Take the front plastic cover off the black IU and you will see the chip (a small pcb ) that you need to replace. Unplug the connector and remove the old board. Put the new pcb in and connect the connector. If you need the black chip(pcb) ..... Copylite sells them cheap.
      • suresh
        OK, thanks
        I open the front plastic cover, taking the 5 screws out, and pulling the blue rod out so I could see the chip.
        I replace the chip. reinstall the cover and slide the Imaging unit back.
        And now this is the error on the screen:
        "The wrong imaging unit is set.
        Please install the correct Imaging Unit, and close all doors"
        • blazebusiness
          • 1250
          Maybe you did get the wrong chip or a bad chip then....try ordering another from Copylite....never had a problem with their reset kits
          • suresh
            try to register in copylite, but I'm not a reseller.
            thanks anyway
            • rosaro75
              • Mar 2009
              • 87
              for 110v machine and 220v machine the chip differs. so confirm it clearly. please ask the seller wheather it is for 110v or 220v.
