2500c giving off a deafining squeal
  • ckk0813
    • Apr 2011
    • 3
    Is this the fuser?
  • Masterchief
    • Apr 2011
    • 280
    Hi and welcome, can you please confirm the machine model to bether determin a solution to your problem...
    Masterchief
    sigpic
    • JustManuals
      • Jan 2006
      • 9819
      Just Manuals | The Internet's largest selection of manuals | Instant Downloads
      Paul@justmanuals.com
      • ckk0813
        • Apr 2011
        • 3
        squeal
        the copier i have is a toshiba estudio 2500c. Everything I have read points to the fuser. When I crank the machine up in the morning it doesnt squeal until about the 10th copy. So I guess it has to get warm first which further more points to the fuser. Some reason the squeal just doesnt sound like its coming from the fuser. Does any of the outer rollers ever squeak?
        • chad.morris
          I have dealt with this alot and nine times out of ten replacing the fuser solves the problem also try cleaning the paper feed rollers
          • ckk0813
            • Apr 2011
            • 3
            I was hoping for a less expensive option
            im sure a little grease in the right spot could solve the problem
            • excanonguy
              • Jun 2008
              • 173
              Re: 2500c giving off a deafining squeal
              If it is the fuser its probably the scraper blade for the fuser belt, if its too close to the belt it gets a toner build up and can make alot of noise, clean it and move it away from the belt a small amount...move it too much and it will jam.
              • michaelc
                Field Tech
                • Mar 2011
                • 590
                You could always do get the noise going then run the motors to check where it is coming from using the 03 test mode. If you think its the fuser start the drive up but remove the fuser drive fear from the fuser so it doesnt drive.
                It didn't say that I couldn't do it in the manual.
