Hello and HELP! (please.......)
  • pronicd
    • Jun 2012
    • 21
    Hi, new here, so please be gentle with me!
    I have just put a new drum and scraper blade in a Nashuatec 3913 photocopier.
    I assume that there must be some adjustments needed as even plain copies are coming out grey across almost the whole page.
    Any help or advice would be very much appreciated.
    Thanks in advance for any help anyone can give.....
    Cheers Russell F
  • Aneurysm
    Administrator
    • Jan 2005
    • 1083
    Welcome to the site.
    • RRodgers
      • Jun 2009
      • 1947
      Re: Hello and HELP! (please.......)
      Are you sure the blade is touching the drum? Are you sure you didn't get any sensors around the drum dirty? Are you sure you put the charge corona back in properly.
      • pronicd
        • Jun 2012
        • 21
        Hi thanks for your insight. I just slid the whole assembly out, and was horrified to see that the scraper blade was no longer pointing down! It had bent back on itself and was pointing up instead!
        It was definitely pointing downwards when it was fitted, so am puzzled as to why it has done this.
        Any thoughts as to why this may have happened and how to ensure it doesn't do it again?
        Thanks in advance, Russell F
        • mrwho
          Major Asshole!
          • 4299
          The blade adhered to the drum and flipped (known, not surprisingly, as blade flipping). When putting a new drum and blade you should always put some toner on the drum and blade (although not on some equipments) or, preferably, use setting powder (a toner-like substance that comes inside cloth bags - you just gently tap the bag onto the drum and blade and the setting powder comes out through the cloth's fibers onto the drum and blade). The toner/setting powder acts as a lubricant and prevents the new blade from adhering to the drum.
          If you want to check the blade adherence by yourself, just grab the old drum and blade, clean them thoroughly with some cleaning product and, after they're dry, try to drag the blade along the drum and you'll see they tend to stick together.
          Mascan42
          Ibid
          • pronicd
            • Jun 2012
            • 21
            Hi guys, yup that was it for sure.
            Have now put it back in (just before I got the reply about the blade flipping).
            Seems to be working fine now.
            However Mr clumsy has managed to break off one of the little plastic locating pegs at one end of the scraper assembly.
            Not an issue - fortunately!
            This time around, apart from the fact that there was toner left on the drum (which I did not clean off) I put the scaper blade on before dropping the drum in.
            Last time I put the drum in first and then the scraper.
            Is there a preferred re-assembly sequence, or is it probably just the lack of toner or powder that caused the problem?
            Cheers Russell F
            • pronicd
              • Jun 2012
              • 21
              p.s. I love your avatar Mr Who? Fantabulous!
              • pronicd
                • Jun 2012
                • 21
                I was just looking and found the service manual forum.
                Realise from the rules that I have to have five posts before being able to ask for a manual.
                Fair enough (does that mean five posts under one thread, or five threads on wonders?).
                However I do have a full manual for a Canon NP 62-16 if anyone needs one.
                Cheers Russell F
                  • 23008
                  Cheers Russell F
                  The blade usually comes dusted with a very small amount of setting powder, and sometimes the drum too, but it's rarely enough. You should always rotate the drum through a couple full rotations in the feed direction to make sure that blade won't flip.
                  There are only two situations I am aware of, of drum blade flipping, if the blade survives initial installation:
                  1) On Sharp Panthers it was not uncommon to flip the blade within the first thousand copies. If it survived 1000, it would last a normal life.
                  2) In situations where the customer runs extremely low coverage (1%) the blade can start to hum or keen because of minimal toner usage. You see, toner acts as a lubricant to prevent the blade from vibrating, grabbing and finally flipping. Too little lubricant, and ... you get the idea.
                  I'm sure that it's more than you wanted to know. =^..^=
                  • pronicd
                    • Jun 2012
                    • 21
                    LOL - no not at all! I like a detailed analysis!!
                      • 23008
                      You'll know if you ever hear that "keening". It's a very high pitch squealing like nails on a chalkboard. It make those little hairs stand up on the back of my neck. =^..^=
                      • pronicd
                        • Jun 2012
                        • 21
                        Interestingly enough it made no alarming sound at all. Not even like you or your spouse might have done when your cat brought in that mouse!
                        • mrwho
                          Major Asshole!
                          • 4299
                          I like your description. Also thanks for the avatar comment - it's from a youtube video of a cat tech.
                          As for the manual, I believe you can place your request - at least you're not doing it on the very first post, and that's what gets people angry around these parts.
                          Mascan42
                          Ibid
                          • pronicd
                            • Jun 2012
                            • 21
                            Which parts do people here get angry around then: Drums, Corona wires, fusers???
                            Will request a manual then if no one objects!
                            Cheers!!
                              • 23008
                              Sorry to say, blackie is just an interesting JPG, sent to me by a friend who's sent me a number of potential avatars. He looks a little like Felix (less 10#). I was "blackcat" long before we had a black cat.
                              Only the kittens, Rosie & Roxie, would have a clue what to do with a mouse. The rest of the group have been domestic for so long that they would probably run from a mouse. Now I wouldn't want to be an insect that strayed into our home. They are usually tortured to death then eaten. Then the cats get hold of any that are left.
                              Mrs. blackcat would most likely try to save the poor mousey from the kittens. I'd be rooting them on. =^..^=
