Having trouble with search.
  • Ginbolero
    • Apr 2013
    • 45
    Hi all. Is it me or is the search on this forum not very good?
    I may be doing something wrong but the results bear almost no relevence to my search key words.
    Any tips would be greatly appreciated.
  • Aneurysm
    Administrator
    • Jan 2005
    • 1081
    Hi Ginbolero, welcome to Copytechnet.com!
    • Hansoon
      • Sep 2007
      • 3385
      Re: Having trouble with search.
      Gimbolero, this is a known issue since years.
      try this link from one of our collegues:
      301 Moved Permanently
      (Those Brits are driving the wrong side of the road, but I must say they know how to make a clever search thingy.... LOL)
      Hans
      • Ginbolero
        • Apr 2013
        • 45
        Perfect. Thank you :-)
        • Synaux
          • Mar 2012
          • 1224
          Welcome Ginbolero!
          Thanks Hansoon!
          • John Kaufmann
            • Sep 2013
            • 115
            Originally posted by Ginbolero
            Hi all. Is it me or is the search on this forum not very good? ... the results bear almost no relevance to my search key words...
            An old problem, as Hans said, and his solution will help. However, note that it's just a control for a script to pass the search to google.com, using Google's "site:" parameter pointed to "copytechnet.com" -- so you can do that yourself:
            Code:
            <search terms> site:copytechnet.com[/]
            (trailing slash "/" is shown as optional)
            That's especially useful if you want to narrow your search for better granularity. For example, if your interest is Canon copiers or printers, you can correspondingly narrow the search domain:
            Code:
            <search terms> site:copytechnet.com/forums/canon[/]
            ([BTW: If you look on the Home page under "Technical Forums", you will see "Copier Technical Discussion" and "Fax & Printer Technical Discussion", each with a "Canon" category - but both link to the same place. I believe Canon is the only brand for which that is true.)
