Error F246 in Kyocera M2035
  • luislisbo
    • Aug 2025
    The machine is with permanent error code F246, actualize the firmware is disconnected from the network but appears immediately turn the error code is always present.
    How do I remove them?
  • Aneurysm
    Administrator
    • Jan 2005
    • 1096
    Welcome Aboard!
    • bob marley
      • Jan 2012
      • 1339
      Re: Error F246 in Kyocera M2035
      Welcome
      If u still searching for solution go to http://www.copytechnet.com/forums/ky...mita-copystar/
      good luck
      Live for yourself and you will live in vain. Live for others, and you will live again
        • 23010
        This is the newbie check in area, where you can introduce yourself. If you have a Kyocera question you should post it in the Kyocera section.
        Here's the short answer, though. Most likely you are getting some sort of unsuitable data coming to the MFP's IP address. It might be a wrong print driver, a corrupt document or website, or some type on non-print data that the machine cannot interpret. If the error pops back up the moment it's on the network, that's the confirmation. =^..^=
        • luislisbo
          The problem is that the machine is disconnected from the network to prevent corrupted data entry and yet at power starts with the error, not allowed to enter the service mode 10871087 to reset the memories and see if you can exit the error
            • 23010
            There is no magical reset for cf246. It clears by itself upon initialization. If the error occurs without a network connection you have corrupt firmware, corrupt CODE DIMM, or bad Main Board, in that order. =^..^=
            • djcan
              • Jun 2014
              • 11
              hello source of the problem computer user sends incorrect file
              1-solution, you can update the machine software
              2-solutions to drive in the computer by changing the IP number of the machine can solve the problem by introducing a new port
              Godspeed
