ricoh mp402 problem "install the toner cartridge"
  • deimosltda
    • May 2020
    • 2
    Good afternoon, I am a technician and I have the following problem, MP402 when I turn it on, a message appears on the screen, which says "install the toner cartridge".
    I put in a new one and follow the message.
    Change the PCDU, check the contacts of the chip ID.
    Consult several technicians and I can't find the solution.
    I need help
    • 22808
    Re: ricoh mp402 problem "install the toner cartridge"
    I need help
    What have you tried?
    Do you have a manual?
    Are you qualified on this product
    Give us more info to help you.
    Post error log and service logs In pdf format
      • 35062
      Post your problem in the proper Technical Forum. It will be seen by all the Ricoh techs and not just those of us that check the system forums.
      • deimosltda
        • May 2020
        • 2
        Hello, thanks for answering.
        I have been a photocopier technician since 1985. Currently I am maintaining Ricoh proc 9100, proc5100 and others
        I have the technical manual.
        When turning on the machine it says:
        Machine status: Unit Setting error.
        Copier, printer: Error Ocurred
        Toner Cartridge Setting error: Toner Cartridges are not set: Black
        Open the following part. (Door) then set correctly
        Actions:
        a- Put in a new toner.
        b- Change PCDU and toner
        c- Check chip ID contacts
        d- Check continuity of wires from ID chip connector to main board
        e- Consult other Ricoh technicians, nobody knows how to solve a problem
        Can I send you the photographs in JPG?
        My email is digilaser@yahoo.com
          • 35062
          Actions:
          Only 2 posts and this is your second one. Your lucky I am in a good mood tonight or you would be collecting Red Cards. Now post your machine problem(s) in the correct Technical Forum as I advised yesterday. And see a shrink about your problem with taking advice.
          • fshead
            • 2356
            are you using ricoh oem toner?
            did you try putting the non read toner into a different machine?
            I dont know the 402 but i would see if there is any tabs,or switch outside of the toner reset chip..
            • anothertech
              • 1714
              Try replacing ID chip. part # M1873360 and check wiring from the chip back to the board.
