Large Format Forum
  • aAandy
    • Apr 2012
    • 370
    Large Format Forum
    in these tough times, i'm finding many new clients wanting older large format machines repaired - thought it would be a good idea to setup a Large Format Forum
    there! my 3 cents (inflation)
    • 37521
    Re: Large Format Forum
    I don't know about other manufacturers but with Ricoh wide format copier questions can be found in the regular Ricoh technical forum. Most Ricoh dealer tech work on wide format as well as regular MFP.
      • 23009
      Canon and HP wide formats can be found in their respective forums. Kip will be found under "Other". =^..^=
      • Aneurysm
        Administrator
        • Jan 2005
        • 1083
        Looking for opinions, would a dedicated "wide format" sub-forum be a better way to go than the current setup?
          • 37521
          It would just be one more forum I would need to follow to see if I can be of help. But then again I am retired and have the time.
            • 23009
            I do most of my searching from Google:
            site:Copytechnet Home keywords
            So it doesn't really matter what forum it's in ... Google generally finds my keywords.
            Just my opinion. =^..^=
            • JR2ALTA
              • Feb 2010
              • 2033
              Probably, they're such a unique animal but much more close to our wheelhouse than cash registers, etc.
              I think it would fit nice into the 'Fax & Printer....& Wide Format" forum.
              • Synaux
                • Mar 2012
                • 1224
                The forum seems to be adequate as is, but Wide Format & Inkjet might be appropriate.
                But then again, I feel that such a section would get far less exposure than the old Cannon/HP/etc sections. Not much of an answer I'm afraid
                  I think that a separate forum is a good idea... maybe sub categories InkJet - Laser. as time grows (and Interest) maybe split into brands between the two sub categories to make it eaiser.
                  Canon has the inkjet and Oce' (sub company) does laser
                  Epson only inkjet
                  Ricoh I believe covers both
                  just my 2 cents
