Private Message/Notifications Issue
  • CoreyAbels
    • Dec 2014
    • 91
    I'm not sure where to post this issue, I have tried the Contact Us section of the website and I have not received a response.
    I cannot send private messages due to the system thinking that I have 65k messages stored in my account. I do NOT have ANY messages stored anywhere. Is there someone who can assist with this issue?
    If this is not the appropriate avenue, can someone direct me to a person, or web admin to fix the problem?
    Thank you!
  • tsbservice
    Field tech
    • 8018
    Re: Private Message/Notifications Issue
    Good news is you're not the only one.
    Bad news is afaik this is forum glitch...
    • CoreyAbels
      • Dec 2014
      • 91
      Fair enough, I did read through a previous post in this section referring to the same problem AFTER posting my question... LOL
        • 23008
        You did exactly the right thing. Posting here will get the attention of Aneurysm. I'm sure that it will be straightened out shortly. =^..^=
        • CoreyAbels
          • Dec 2014
          • 91
          Much appreciated!
          Sent from my Pixel 7 using Tapatalk
            • 37502
            While you are waiting for the administrator to login, what do you see when you click on Private Messages? In Inbox do you see any messages listed? If you do there should be a check box at the top right. If you do, click it to place a check mark in it which will select everything in the Inbox. You should then have an option at the bottom for Selected Messages and then select Delete as the action you want to do with the selected messages then click Proceed. Do the same thing for Sent Massages. Once you are able to clear one of the folders, Folder Control for that folder only might show that you messages in some other folder and then an option to (Empty Folder)? If so, click it and see if the problem is cleared.
              • 23008
              There's something magical about the number 65,535. It's the binary number "1111111111111111".
              It's come up before, when I had an issue with a copy count collecting software. Each time I initiated the program to collect copy counts it generated 65,535 corrupt print jobs for each printer. Our IT department was somewhat unhappy with me.
                • 37502
                I am familiar with 65,535. 65,535 is 216-1 and is often used in unsigned binary for -1. Back when we occasionally had to manually enter HDD parameters on PCs. It was what had to be entered for the landing zone when the actual track was -1.
                I have also seen it as a register over flow indication such as with Ricoh color models on the toner level memory with a bad RFID chip or board
                • CoreyAbels
                  • Dec 2014
                  • 91
                  Thank you for the response
                  I've attached a couple of screenshots for reference. Thanks guys!
                    • 37502
                    On the second screen shot have toy tried clicking where it says (Empty Folder)
                    • CoreyAbels
                      • Dec 2014
                      • 91
                      LOL, multiple times my friend, multiple times.
                        • 37502
                        Then you are just going to have to wait until aneurysm show up.
                        • CoreyAbels
                          • Dec 2014
                          • 91
                          No worries!
                          • B0265
                            • Jan 2007
                            • 718
                            I have the same problem, did yours get solved?
                            • tsbservice
                              Field tech
                              • 8018
                              Probably not because I've just received this message when trying to PM him:
                              CoreyAbels has exceeded their stored private messages quota and cannot accept further messages until they clear some space.
                              So probably you're stuck with broken account in this matter. I wish can assist you in some way by sending on behalf of yourself or something else
