sent messages
  • boutn
    • Jun 2016
    • 537
    sent messages
    If i go to my private messages, i only see the receives messages/inbox, but no sent items.
    So if i send a message, is it beeing sent and not saved to 'sent items', or is it simply not sent at all?
    • 2621
    Re: sent messages
    • tsbservice
      Field tech
      • 7924
      Re: sent messages
      Your account must be broken then for that contact admin Aneurysm.
      • boutn
        • Jun 2016
        • 537
        Re: sent messages
        Originally posted by skynet
        I may be stupid...but i had already figured out that my sent items should be under 'sent items'. That folder was emtpy though, so thats where my question came from.
        Also figured out that you have to enable it every time you send a message, and you cannot select it if you "quick reply" (Save a copy of this message in your Sent Items folder.)
          • 8105
          Re: sent messages
          PM me i'll let you know if I receive it.
          • tsbservice
            Field tech
            • 7924
            Re: sent messages
            No need to be sarcastic dude everyone here is trying to help. Obviously your PM folder is somehow broken, by default you don't need to do anything special to have sent messages in folder.
              • 2621
              Re: sent messages
              Try a different web browser.
                • 36887
                Re: sent messages
                Check Settings - My Settings - My Account - General Settings - Messaging & Notification - Private Messaging - Sent Private Messages: It is probable set for "Don't save a copy of sent messages." If I remember correctly, that is the default.
                • John Kaufmann
                  • Sep 2013
                  • 114
                  Re: sent messages
                  As slimslob said, "Don't save a copy of sent messages" is the default, which you should be able to change. However, even if you leave that default, you should always get a small box before sending if you want to save a copy.
                  • boutn
                    • Jun 2016
                    • 537
                    Re: sent messages
                    Thank you for that!
