can not login
  • boutn
    • Jun 2016
    • 552
    can not login
    Hello,
    My colleague joe_vanacker can't login to the forum anymore.
    Even password reset does not help.
    Who can help him?
  • boutn
    • Jun 2016
    • 552
    Re: can not login
    Not all at once please...
    Even making a new login only works for a while whereafter logging in doestn seem to work anymore.
    He thinks it worked fine untill the day he installed tapatalk.
      • 23010
      Re: can not login
      Aneurysm will be able to help. He checks this forum first. =^..^=
      • Aneurysm
        Administrator
        • Jan 2005
        • 1096
        Re: can not login
        The account wasn't locked and everything looks normal. It looks like they login from Belgium so maybe something regional? I'll see if I can login via VPN through Belgium and duplicate the issue?
        • boutn
          • Jun 2016
          • 552
          Re: can not login
          If he tries to log in, he gets login incorrect.
          If he goes to forgot password, click here, no mail ever gets received. He tried making another account on his private mail, same problem.
          He logs in from Belgium indeed, he's on the desk next to mine...so same network/location.
          • Aneurysm
            Administrator
            • Jan 2005
            • 1096
            Re: can not login
            Thanks for clarifying, that rules out a lot of stuff. I see his username linked to y***i@c***s.be with a last activity date of October 25th, it's not locked or awaiting email confirmation, everything looks fine on our end.
            Do you receive emails from us at the same domain?
            Has he tried a different browser? or tried using his credentials from your workstation?
            If you want, I can manually change his password and PM it to you so he can see if that works? let me know.
            • boutn
              • Jun 2016
              • 552
              Re: can not login
              He tried everything above and more, so maybe try sending the PW to me so we can try that way?
                • 37628
                Re: can not login
                You can't get it from your colleague?
                • boutn
                  • Jun 2016
                  • 552
                  Re: can not login
                  his pw doesnt work anymore and he cannot reset it
                    • 37628
                    Re: can not login
                    Then the best bet is to Private message Aneurysm, our only admin, and have him delete the account. Then your colleague can create a new one.
                    • boutn
                      • Jun 2016
                      • 552
                      Re: can not login
                      • Aneurysm
                        Administrator
                        • Jan 2005
                        • 1096
                        Re: can not login
                        Boutin - Check your PM's, I sent you a new temp password that works when I test from here, let me know what you get on your end.
