Search question
  • gwaddle
    • May 2009
    • 782
    Search question
    When I try to search the Sharp forum for service codes I never get results. Example: I searched for "L4-16", which I happen to know is there, and it finds nothing. Am I doing something wrong? The problem is, at least for me, service codes are the most common search I need to do. Thanks.
    I know I should be ashamed of myself. Strangely though, I am not.
    • 22995
    I think you'll get better results if you choose Advanced Search, Search Single Content Type, enter your keywords, then select the forum you would like searched from the drop down list. Try that. =^..^=
    • mrwho
      Major Asshole!
      • 4299
      IMHO the search feature worked fine until some major update some time ago that messed everything up.
      Now I resort to use Google with results only found on this site.
      For example, to search on copytechnet.com about jams, I'd use "jam site:www.copytechnet.com" without quotes.
      Mascan42
      Ibid
