Eautomate and Remote Tech
+ More Options
Posts
  • fireater
    Repair God? not quite
    • Apr 2006
    • 253
    does anyone use Remote tech on here? and your opinions? does it work well on your smartphones?
    I fix copiers ...Well Sorta
    • 23009
    Re: Eautomate and Remote Tech
    We're about 3 months into it. At least from the service tech point of view it seems to do what it's supposed to. We've only had one extended service outage, later explained as a "software upgrade". The techs at our end do not have much in the way of rights. We're frequently calling dispatch to have our dispatcher fix something we fat-fingered in the field. The one negative that I can put my finger on is the systems inability to allow ordering a part that is new to the system. If you're the first to need a particular part, it's got to be created in the system by parts before you can request it. =^..^=
    • Tonerbomb
      AutoMajical Resolutionist
      • Feb 2005
      • 2589
      The new part thing is an E auto issue not a remote tech issue, causes a bad sync error for that call.....................
      Mystic Crystal Revelations
      • apump
        • Mar 2009
        • 160
        we have been using it and I like it. not to many may times where it is down. its easy to use and has several different things I like. you can look at your teams calls look up parts and prices. only bad thing is you order a part and theres nothing to tell you when your part is coming in.
