Desktop Color All in one
  • Bix
    • Apr 2018
    • 1421
    #16
    Re: Desktop Color All in one
    Originally posted by 907tec
    Thankfully, I don't technically have any in my area. The ones I am responsible for are located on cruise ships which only visit from May-September. Last summer, I had repeated MFPB, MEM, and SSDB failures, though (on C3350's). Some of this can be attributed to the poor electrical grid onboard, but it doesn't explain the higher-than-average failure rate. I am probably also letting my hatred for the C35 affect my feelings towards the C3350/C3351. Even though it's easy, replacing the scanner belt is a huge pet peeve of mine. The fact that they still haven't addressed the simplest of issues really annoys me.
    Most probably it is for this. The power supply is irregular. Moreover, being a ship, there will be a lot of humidity and this affects a lot.
    • 907tec
      • 434
      #17
      Agreed about the causes, but there was a significantly higher failure-rate on these small boxes versus the dozen C364e/C654e's spread around the rest of the ship. Duplex (9303?) errors also can't be directly blamed on the power issues, and I sunk WAY too many hours into replacing door assemblies/exit drive assemblies/duplex clutches. My hatred for desktop KM's stems from the old Magicolor "carousel" machines, and they haven't made anything since then to regain my trust.
      • 3ktlc
        • Feb 2018
        • 180
        #18
        Will have to keep you updated on my C3351/C33851fs. We have a few that have been running over 15k/month. Printing to it mostly. Helps with the scanner belt wear.
        • 3ktlc
          • Feb 2018
          • 180
          #19
          first one started having problems with the finisher. Intermittently jamming when it is pushing a set out while the next sheet is entering the finisher. Anyone see this?
          • 3ktlc
            • Feb 2018
            • 180
            #20
            The C3851fs seems to have problems with dry rails in the finisher. Just had the second one cause jamming issues and noise. After cleaning and lubing the rails, working again.
            • 3ktlc
              • Feb 2018
              • 180
              #21
              Update on the C3851fs machines. I would say to stay away from them. The finisher stinks. Outside of the rail issues, the back guide also gets nicked up and needs replacing. Around 70k on the meter. The RADF is starting to jam also. Just like the C35's & BH36's. Guess Konica Minolta really doesn't care about small machines.
              • Asterina
                • Sep 2021
                • 16
                #22
                It is necessary to think about this
