Solution to help repair OPC drums
  • VICENTENAVAS1968
    • Feb 2025
    • 4
    hi guys, i liven in nicaragua. i know drums are cheap but the problem is sometimes getting them in a hurry. we are trying to repair opc drums that have small needle holes. do you know what solution is used to dissolve and then transfer the coating onto a repaired drum? what solvent acid etc ? who sells them ?
    • 16104
    I don't think so. Could be wrong.
      • 36246
      Once pi holes start to develop, the drum is beyond recovery. Any attempt to do so could result in toxic fumes being released.
      • Hansoon
        • Sep 2007
        • 3340
        Drums from China are soooo cheap...
        ....and they all come anyway from China.
        BTW, rebuilding is very easy.
        Hans
        " Sent from my Intel 80286 using MS-DOS 2.0 "
          • 22870
          Back in the old days on Mita, with selenium tellurium drums that used a cleaning corona unit rather than a cleaning blade, we would use a very small amounts of enamel nail polish to fill low spots (dots). It worked for two reasons: 1) there was no cleaning blade, so no mechanical cleaning issue, and 2) it left a very small white dot uncharged. On analog technology it leaves a nearly invisible white flaw in the image.
          I experimented on a few drums in the early 90's. It will not work on any drum that uses a cleaning blade for two reasons: 1) It leaves a teardrop shaped area that does not clean, damages the cleaning blade, and eventually becomes a line, 2) It leaves a very small area uncharged. On digital technology that shows as a black area on the image.
          Your only recourse is to replace the drum.
          • Strands
            • Apr 2024
            • 1
            Originally posted by VICENTENAVAS1968
            hi guys, i liven in nicaragua. i know drums are cheap but the problem is sometimes getting them in a hurry. we are trying to repair opc drums that have small needle holes. do you know what solution is used to dissolve and then transfer the coating onto a repaired drum? what solvent acid etc ? who sells them ? Block Blast Puzzle
            Some have experimented with UV-curable resins or lacquers used for optical discs, but the challenge is maintaining the drum’s electrostatic properties.
