High volume recommendation
  • copicatt
    • Nov 2008
    • 366
    A current customer just called me wanting to know what would handle the job he is about to take on: He is going to start printing statements for banks. He says it could easily get to 2 million pages per month. He wants to spread it over 3 or 4 machines of the same model. He would rather not buy new. What on earth would handle this sort of thing. Most of my customers are 2k-35k per month. That would be 500k on each of 4 machines per month. Geez. which would be about 24k per day per machine. I don't think I could support that but told him I would look into it. Sounds like a major headache. Ir105? That is still 6 mil per machine per year. If it gets to that. Thanks!
  • iMind
    Vacuum Cleaning Expert
    • Mar 2008
    • 1116
    Check out his machine very reliable:
    Used Ricoh AF 2090 Copier Manufacturer exporting direct from Germany
    Ricoh Aficio 2090 - IKON Office Solutions
    • Titan1969
      • Oct 2009
      • 14
      Konica 650 - 750
      These machines have been good to us. They can run a lot ( you would need 4 machines for sure )and parts are not terribly expensive being Konica. We have several with 4+ million. You should be able to pickup some good used ones, since this models been out a while.
      Caution...dont try and save money on aftermarket toner on this model. Youll be very sorry, stick with OEM toner. Yes I do use some aftermarket, its not all bad.
        • 23009
        Copystar CS-8030/CS-820
        The Copystar CS-8030/CS-820 can support this volume over (4) units, but let me be the first to say that this kind of volume will support offset printing at a lower CPC.
        If you do get this gig you'll need 1/2 to 1 tech just to maintain them. Good luck. =^..^=
        • davidj7
          • 1107
          i was running 8 105's for 24/7 , well they ran for a month till the work ended. 7 of them worked throughout, one machine was always being used as spares to support the rest.
          a machine is only as good as your tech : source:screwtape ; the scary one
          • D_L_P
            Self Employed
            • Oct 2009
            • 1196
            A couple of Canon ir110 or ir150 would easily handle this volume. In our territory we have a print shop running 700-900k per week, they have 60 million on them and counting.
            • Juggy
              Technical Support
              • Sep 2007
              • 101
              If you really want a great machine for printing statements you can go for Kodak Digimaster Ex series machines which can run 24/7 and 2 million a month is just nothing for the machine. If your price conservative you can go for Konica minolta Bizhub 950 / 1050 Good luck
              • OMD-227
                Have a look at the Sharp Hercules series (MXM850, MXM950 & MXM1100).
                I look after alot of these machines, super reliable, insanely quiet during use, fastest ADF on the market and real easy to service.
                You can also setup Tandem Copy/Print mode to share the load of the large jobs across 2 or more machines on the network. Therefore making a big job completed much sooner.
                We recently put a MXM1100 into a client's printroom that previously had 2 Sharp ARM700 Dragon's. The Hercules did 1.5mil in the first month alone, and goes perfectly everyday.
                My 2 cents.
                • copicatt
                  • Nov 2008
                  • 366
                  thx for the input guys. The customer said off the bat, he will have a job of 30k per week and will grow from there. We talked and he's wanting to go with 2 machines to start. Maybe this is the only job he will have, who knows. thinking about putting a couple of 5020's in there to start and upgrade from there when the need arises....I have one 5000 running this volume and it seems to be holding up so far.
                  • wagon
                    Village Idiot
                    • Dec 2006
                    • 654
                    KM7222...... - As a job creation project.
                    (Runs and hides)
                    If you are hitting your head up against a wall it always feels better when you stop.
                    • markdmt
                      • 76
                      Sounds like a good job for the Canon IR110 printer. We have more than 20 available used tested or refurbished. we also train people to do their own service which can be very useful in this economy. please email or call and speak with Tim or Mark 801-397-1826 mark@dmtpublishing.com tim@dmtpublishing.com we would be happy to give you an estimate. We have worked with other equipment brokers and OEM's THX
                      • Hemlock
                        • 432
                        Oce' VP6250; a singe machine would handle that volume. I have 3 and am amazed by the speed & reliability. (Hard to believe this is the same company that foisted the CPS series on the world.)
                        “Anti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge.'” (Isaac Asimov)
                        • Joe Foe from Buffalo
                          • 399
                          Riso has the best option for high volume Mirc toner use. RISO Introduces High-Speed Inkjet Accessories for Envelope and MICR Check Printing. - Free Online Library
                          Call me @ 716-832-4950 for details and a price ask for Ward.
                          • rockin57rod
                            • Mar 2008
                            • 73
                            If you check into the customers that do this kind of work, and run volumes in the millions...there is only one machine that was ever made to do this type of job. It is a Xerox 4635, and I back that with 30+ years of experiencing everything that has been previously listed. Try it, you'll like it. Your customer will love you forever, and you will both make a good dollar.
                            • alien
                              Re: High volume recommendation
                              -KM bizhub 1200
                              konica minolta bizhub 1050 e
                              are the best!
