Rubber rejuvenator? any suggestions
  • Synaux
    • Mar 2012
    • 1224
    #46
    Re: Rubber rejuvenator? any suggestions
    Originally posted by ZOOTECH
    That's sounds like it hurts ;(.
    "Relax sir/madam, it is merely an exfoliant that will make you feel young and rejuvenated"
    • jenagrey8585
      #47
      Over time, paper dust, ink residue and other debris accumulate inside the printer and coat the roller. When that happens, the roller cannot move freely, and paper jams can result
      . Put your printer in draft or economy mode
      Run your printer's cartridge cleaning tool once a week. Remove the toner from the printer and put a small piece of masking tape over the window or drum.
      • Synaux
        • Mar 2012
        • 1224
        #48
        Okay...Maybe I am drunk, but you are insane if you think that draft or economy mode will help any "printer."
        Clean the damn rollers and earn your keep (if that is your Yob)
        NEVER sacrifice quality--hell teach them how to clean the "rollers" if you are that damn lazy....
        • jenagrey8585
          #49
          Give me a break mate i am just sharing my views i am not saying i am the expert of this, i just want to help and thinks that may be this info will help
          • Hansoon
            • Sep 2007
            • 3389
            #50
            Yes, also sacrificing cute little fluffy furry animals to an obscure deity seems to help a lot I have heard. But only when doing at the same time that Indian rain dance....
            Hans
            • redneckstylin
              • Sep 2011
              • 173
              #51
              Good afternoon,
              Since selsol is no longer offered by densi nutone......what is everyone's go to feed tire cleaner?
              • jose antonio
                • Dec 2012
                • 119
                #52
                I use Isopropyl alcohol 70%..works great, you can also try " blanket wash" ( used in printing industry) if you have acces to it.
                Antonio
                • Samanator
                  • Sep 2017
                  • 579
                  #53
                  When I clean gray feed rollers I usually start with blue glass cleaner or water. If they seem a little dried out, I hit them with some WD-40.
                  For most all other rubber I use WD-40.
                  WD-40 is easy to obtain and moreover, it works.
                    • 16416
                    #54
                    Depending on the type of feed rollers, sometimes I'll scrape/sand the old dried out rubber off in order to get down to some good rubber. That doesn't work on all rollers, tho.
                    • tsbservice
                      Field tech
                      • 8020
                      #55
                      Originally posted by redneckstylin
                      Good afternoon,
                      We use this:
                      Platenclene- Printer roller cleaner/restorer | AF International
                      • Hansoon
                        • Sep 2007
                        • 3389
                        #56
                        We use this:
                        [ATTACH=CONFIG]54792[/ATTACH]
                        +1
                        Hans
                          • 16416
                          #57
                          Quick question: Do you view rubber rejuvenator as a temporary or permanent fix?
                          • Samanator
                            • Sep 2017
                            • 579
                            #58
                            Not sure.
                            Is extending the life of a given expendable a temporary fix?
                            If I have to put it in a binary category, I suppose it would fall into temporary fix.
                              • 37532
                              #59
                              Antonio
                              Isopropyl alcohol is readily available in the US in solutions of anywhere from 50% to 91%. It is a common household antiseptic. I also will dry out many rollers and cause them to crack as it draws out the natural oils.
                                • 16416
                                #60
                                Originally posted by Samanator
                                Not sure.
                                The reason that I ask is because I used to use it a lot but most of the time I would have to go back and replace the feed tires with new. Because of that, I only use it in a pinch and I always go back and replace later.
                                I have had it to last for a long time but I'm never comfortable with it.
