Is there a 'Pen Drill'?
  • JR2ALTA
    • Feb 2010
    • 2033
    I am looking for a small battery powers or electric drill. This would be for making small holes in plastic. This would be for MacGyvering out in the field. I've done several Google searches but not finding the perfect solution.
    Thanks!
    This looks like it but I have no idea why a manicurist would be drilling into nails, so maybe it's not a "drill"
    Professional Electric Mini Manicure Nail Art Drill Pen 6 Bits Sanding File Toolz | eBay
  • subaro
    • Oct 2010
    • 1274
    Re: Is there a 'Pen Drill'?
    No, that is a mini rotary tool, it may do he job but the chuck to hold the bits might be a problem. anyway see the link below for a manual one that worked fine for me. it is small light and even drill metal.
    Push Drill and Mini Drill Set | Princess Auto
    • vigour
      • Aug 2010
      • 1038
      I think you found it.
      It is a knockoff of a DREMEL tool, which can do many tiny detail tasks, including drilling.
      You could also buy a tiny bit insert for your power screwdriver or carry a small self tapping screw
      Multi-Use:
      Carving, Engraving, Routing, Grinding, Sharpening, Sanding, Polishing, Drilling and more...
      • Corder
        • Nov 2014
        • 105
        Dremel
        Of course it's a little larger than pen.
        • Canon345
          Hitachi 725405 3/8-Inch Keyless Conversion Chuck for 1/4-Inch Hex Impact Drivers - Power Drill Chucks - Amazon.com keyless Hitachi chuck
          Amazon.com: Hitachi DB3DL2 3.6-Volt 1/4-Inch Hex Drive Screwdriver: Home Improvement
          Carbide and Alum cutting bits.
          Amazon.com: round tree carbide: Tools & Home Improvement
          This should be in your kit as well. Its a nice, strait and adjustable driver. I cant see any flaw with this either compared to the Panasonic's that some techs use and cost three times as much!!!
          We use one around the shop too. Its rare you find such a useful and quality tool for such a great price.
          • NeoMatrix
            Senior Tech.
            • 3513
            Is this what your looking for?
            I use it to drill holes in thin steel plates an plastics for a fix-in-the-feild
            It's only good for small jobs but it always in my tool case handy for that repair job.
            • Tonerbomb
              AutoMajical Resolutionist
              • Feb 2005
              • 2589
              Thanks!
              JR here's a link to the drill I carry for the occasional need the bore a small hole, it works great and is fairly light weight. It mainly stay's in the vehicle until needed, and if you surf a bit , it can be had at a reasonable price............
              Vintage Stanley Yankee No 03 043 Push Drill with 8 Yankee Bits | eBay
              Mystic Crystal Revelations
              • rapidocument
                Multibrands Tech
                • Jul 2012
                • 381
                Check out this tool,
                drills, cuts, grinds, sands, etc. also has a universe (wide array) of accesories, do not buy the nails tool, go for something serious like this DREMEL cordless
                Find the right tool for your project. Since 1932, Dremel® has been helping Makers with its full line of versatile, easy-to-use tool systems that deliver the perfect solution for almost any project!
                it's the one I use either in the shop or outdoors, no need to connect it when working at customer's premises.
                My INSTAGRAM https://www.instagram.com/reparacion_impresoras_oaxaca
                • ZOOTECH
                  Senior member of CRS
                  • 3375
                  [ATTACH=CONFIG]28336[/ATTACH]
                  This is the one I've used; with the collet, it can accept most smaller gauge bits (but it is manual, but with sharp bits, how much effort would it take)?
                  If only I could find where I left it.
                    • 23007
                    If you can finish the job in 10 or 15 minutes the battery powered version is fine. But for a durable tool, go with the corded version. I've had 4 or 5 Dremels over the years, and the battery powered versions just don't hold up to continuous use:
                    Dremel 4000-2/30 120-Volt Variable Speed Rotary Tool Kit - Power Rotary Tools - Amazon.com
                    • subaro
                      • Oct 2010
                      • 1274
                      In my earlier post on this subject i made a link to a manual drill tool. This is great for plastic and don't let the size fool you, this tool gets the job done. it can get in places a drill cannot and more.
                      Having said that , i am shop based now and use a combo set i asked my boss to purchase. Its a porta cable 12v combo set. comes with drill and driver, bag, two battries and lithium. These are awesome, i hardly ever use my 8 inch number 2 anymore, i always reach for those. I have modified the bit system to have a reach of about 10 inches which i can shorten at will. I also use the driver more than the drill to REMOVE AND INSTALL screws, Yes install also. The torque on this tool is great and if one is carefull on how to use it, will never strip even on plastic. i use in on plastic at will. see lowes website for the specs on this combo.
                      Ocassionly i go out on calls, and although my tool bag is now disoriented, [ as i have some on the bench and in the bag] i reach for the driver first.
                      The chuck on the drill can hold even a needle, so its usefull and if i have to go back in the field [ lord forbid ] these two is a must have. the driver definitely in my bag and the drill in the car. the driver is a bit of weight, but what it does more than compensate for the job time and satisfaction. It also has a light .
                      I do a lot of rebuilds at the shop and use these tools quite a lot, and the battery last about three weeks before it recharges. recharge time is about 20-30 minutes.
                      bought it on sale for 99 dollars at lowes two years ago and well worth the money.
                      You also get to use it for around the house and don't forget the carrrrr.
                      My intention to start a thread on tools for the trade.
