Asking for the best copy machine type - NEED HELP
  • A.A.S
    • Sep 2025
  • Jaycat718
    • Oct 2013
    • 70
    Re: Asking for the best copy machine type - NEED HELP
    When you say "we won't be using it that much". What is the total estimated monthly volume for the machine?
    • A.A.S
      Thanks for replying ...
      It will be low volume / less than 1,000 copies/mo.
      Our requirements:
      -Paper size: A3, A4
      -Fax
      -Scan
      -Wireless
      • Tonerbomb
        AutoMajical Resolutionist
        • Feb 2005
        • 2589
        you can make any non wireless copier wireless if it has a wired network port by using a wireless adapter from say netgear or linksys. You don't have to pay big bucks for an OEM wireless kit...........
        Mystic Crystal Revelations
        • Jaycat718
          • Oct 2013
          • 70
          If it's less than 1,000 copies a month, i would recommend the following:
          Canon C3330I
          Canon C5255 (although might be a bit overkill for 1,00 pages a month)
          You can buy a wireless connectivity kit for any machine and turn it wireless. I have set about a dozen of these up. They're inexpensive. Buying a copier with wireless already built in, is going to raise the price Significantly.
          This route will save you ALOT of money. The c5255 will need an additional fax kit installed; whereas the c3330i comes with fax built in. For your low volume the c3330i will serve the purpose you need, bundled with the added Wireless Adapter.
          • allan
            RTFM!!
            • 5462
            In you case i would not make financial sense to buy a new machine see if there is a company that would be willing to rent out a second hand machine on a cost per copy basis.
            Whatever
