GBC Shredmaster 5260X
  • copyman
    Owner / Technician
    • Sep 2005
    • 4792
    I usually don't mess with shredders but a good customer asked me to look at this beast. It works fine but reverse doesn't work, button doesn't click like forward. I didn't want to take it apart before doing some research. In parts diagram switch looks like it is part of the control board and cost like $500!
    Just curious if anyone has seen this before and if switch can be bought by itself or can be taken apart & cleaned?
    Or if someone has a used one to sell?
  • NeoMatrix
    Senior Tech.
    • 3513
    Re: GBC Shredmaster 5260X
    I haven't worked on this model.
    Sounds like there is no reverse power shunt to the main motor start capacitor.
    The start capacitor might be blown; I've seen that a couple of times.
    The motor start caps are not hard to change.
    HTH
    • Iowatech
      Not a service manager
      • 3930
      I occasionally worked on shredders while I was at the mothership, and if NeoMatrix's information doesn't work that machine probably will need a new control board.
      I suppose you've already cleaned the entrance sensor really well. So no need to mention that.
      • copyman
        Owner / Technician
        • Sep 2005
        • 4792
        Attached is picture of switch I need. I looked on digikey and there are 12,000+ rocker switches. haha
