Formax 8902CC Paper Shredder Won't continue running
  • Doug James
    • Jan 2012
    • 935
    I am a copier tech that is helping a disabled community with there paper shredder. A formax 8902 CC When you press start it goes in reverse. Then the belt stops, the reverse light comes on, then it moves forward for about 30 seconds. Then stops then beeps 10 times. Does anyone know where I can get tech advise for this or service manuals... Thanks !!!
  • exCSER
    • Mar 2009
    • 98
    Re: Formax 8902CC Paper Shredder Won't continue running
    Hi Doug,
    Sorry I can't tell you where to get a manual for it, but I've opened up a couple of different shredders and found that they make a mess of themselves inside the casing, causing problems like you described due to the sensors getting coated with paper dust. You might try opening it up and cleaning it out to see if it helps.
    Good luck
    • kingpd@businessprints.net
      • 921
      Hi,
      I do Formax equipment to a degree but never the big shredders. I don't have the 8902 but have the 8802 which should be the same mostly. The service manuals on these aren't really service manuals, as mostly these machines are highly mechanical but do have some boards in them. I'd do the recommended cleaning procedure in the attached manual and see what happens, then start basic, clean the button/switches. If its going in reverse when you turn it on right away almost sounds like something switch wise is a bit stuck.
      After it stops does it ever perform normal at all? I don't recall if your model and any sensors like some of the smaller units but sometimes they'd go wacky, like if it detects a finger touching a certain part it emergency shuts off.
      FD 8802 Op-Maint Manual-Rev 1-web.pdf
        goggle the manual I saw it online.
