GBC Ultima 65 laminator
  • deputydogg
    • Nov 2015
    • 172
  • deputydogg
    • Nov 2015
    • 172
    Re: GBC Ultima 65 laminator
    Update. The machine runs constantly when powered on, no control panel buttons have any affect.
    • kuby
      • Oct 2007
      • 1414
      Bad switch?
      • wjurls
        • Feb 2017
        • 505
        The control panel PCB is notorious for failing on these. Often times causing the motor to run backwards as well.
        If it runs constantly you might also have a triac problem.
        I would start with the Triac (You can find a match at an electronic supplier) and if you still have issues replace the PCB and membrane.
        07050703 TRIAC
        704090313 SWITCH MEMBRANE (RUBBER) 1
        706011113 CONTROL PANEL PCB ASSY. 1
        Lee
