Aurora AS1200X paper shredder
  • Jack Perez
    We have an Aurora AS1200X paper shredder that runs, but only functions in reverse. It will not shred paper submitted. Is this something that can be handled with some instruction or can you provide a name of a repair facility in midtown Manhattan? Thank you.
    Jack Perez
    Jack_Perez@ajg.com
  • raym
    • Apr 2005
    • 62
    Re:Aurora AS1200X paper shredder
    hey jack, i\'m not familiar with the aurora shredders but most have sensors in the middle of throat where you put paper into m/c. locate the senors/eyes and make sure they are clean. if that doesn\'t help, you may have a bad on/off switch or a control board problem. at least thats my experience on fellowes shredders.
    good luck,
    ray
    • raym
      • Apr 2005
      • 62
      good luck,
      ray
      • Leslie Vance
        Jack Perez
        Jack_Perez@ajg.com
        Hello guys!
        I understand your problem for that open shredder machine and correct the paper feeding rack correctly it will indicate or otherwise take user manual and check it out yourself if your machine is in validity period call a company to repair it...
        • gregoriojc
          • Aug 2008
          • 56
          shredder
          check the bin full sensor or micro switch if it is activated ,if not replace controll board because the board detects over load that why it reverse if you can repair the board replace the memory ic , its only one 6 pin memory ic on the board good luck.
          gregoriojc
          • Leslie Vance
            I agree with gregor information for that problem jusyt checkout the ic and plug out and clean after that insert and on the switch ....
            Paper shredding
            • stars1
              Paper shredding
              Yeah, agree with you. Or send the paper shredder to local repair shop.
