Parallel to RJ45 cable configuration for Fidelio
  • JuniorCopiertech
    • Aug 2025
    Hi,
    I'm want to use a printer using parallel connection connected to my Fidelio Station via its RJ45. Is this Possible?? Following on the specifications this can be done. I would like to have the Pin configuration for this Parallel to RJ45 cable... I've tried several one but without success. Thanks for your help..
  • JustManuals
    • Jan 2006
    • 9838
    Re: Parallel to RJ45 cable configuration for Fidelio
    Try Googling it. I'm sure you'll get hits.
      • 23009
      Like he says. It's called an external print server, and they make them for TCP/IP to USB, or TCP/IP to parallel. Usually less than $50 US. =^..^=
