Kyocera printer set to print with Form Overlay
  • copyman20
    • 207
    Greetings guys
    setting up a Kyocera FS 4200DN with macros for form overlay. I have 4 file (2 image and 2 macros) that need to be on the SD card for calls from a logical printer. Every time I send the macros using IC Link, it only saves 3 files to the card. I have tried to send the files up one at a time and it is successful and the overlay operation work. however, it will place it in the RAM and not the card. so when I reboot the printer, the files disappear.
    anyone out there working with something similar?
    Thanks in advance
    • 23007
    Re: Kyocera printer set to print with Form Overlay
    Is there any reason that you couldn't just connect a SD card reader directly to your PC, and copy/paste the files directly to the SD card?
    Back in the day when we had trouble using IC link to upload barcode fonts to the CF card, I would pick a machine in the office, then struggle to get IC link to work properly just once. When I finally got a proper upload, I would copy the data on the card to a folder on my PC. Then I could copy/paste the data any number of times with 100% success to my CF card reader.
    I seem to recall that there is a choice in IC Link of whether you want the data stored on the DRAM or the SD card. =^..^=
    • copyman20
      • 207
      I'll try that.
      will update with results.
      thanks
      • copyman20
        • 207
        Well, copied files directly in to SD card and the printer reformatted the card.
