Lanier MP C3002
  • 88hawkfan
    • Jun 2014
    • 76
    Lanier MP C3002
    I have a Lanier that is no longer able to scan to gmail, I've seen posts for the other manufacturers concerning a TSL change implemented by Google but haven't seen any remedies for the Ricoh machines. Anybody have any input or solutions I'm overlooking?
    • 37240
    Re: Lanier MP C3002
    Try changing port number from 465, SSL port, to 587, TLS port.
    • 88hawkfan
      • Jun 2014
      • 76
      Re: Lanier MP C3002
      Tried the different port numbers when I first started testing for the customer. I'll have to start studying up on the differences in TSL to see if it's an easy fix.
      • Tonerbomb
        AutoMajical Resolutionist
        • Feb 2005
        • 2589
        Re: Lanier MP C3002
        Is your frimwar current?? if not update it first.....................
        Mystic Crystal Revelations
        • 88hawkfan
          • Jun 2014
          • 76
          Re: Lanier MP C3002
          Everything is current and all was working as a test bed before Google updated their TSL. I'm beginning to think I will need to issue a device certificate before google will let the copier connect.
          • 88hawkfan
            • Jun 2014
            • 76
            Re: Lanier MP C3002
            Updated firmware again and all is working as it should be, the account is a ways away so rather than picking and choosing I updated all the firmware so I'm not sure which one actually fixed it. Thanks for the help guys.
              • 37240
              Re: Lanier MP C3002
              That's what I usually do.
