mpc 2050,pdf
  • tullio
    • Feb 2012
    • 268
    mpc 2050,pdf
    The machine (MP 2852sp) hangs only when printing PDF. I reformatted the HDD, reinstalled the printer driver and performed cold reset but still same problem.Firmware update is not yet done because I do not have access to my-ricoh.com. I have to ask my technical manager to provide me firmware for the machine. Any solution other than firmware update?
  • Elmo
    • Feb 2010
    • 541
    Re: mpc 2050,pdf
    is i just when printing all pdf
    or just 1 particular pdf
    it is possible that some of the pdf requires postscript fonts
    does the machine have a postscript option installed
    I Used To Live To Fix Things Now i Fix Things To Live
    • houserman
      • Jan 2011
      • 27
      Re: mpc 2050,pdf
      I have encountered this problem myself but every time was solved by reinstalling the drivers from ricoh-europe.com/downloads. Just instal the PCL 6 drivers. good luck. If you need firmware I can help in private message.
      • tullio
        • Feb 2012
        • 268
        Re: mpc 2050,pdf
        OK.THANK YOU
