Scanning sharp mxm 453
  • davebtech
    • Apr 2015
    • 175
    75% works 25% scan goes nowhere..... Anyone have any ideas? Some people on network have lost connection all together.thanks for any input
  • sharptech1
    • Oct 2011
    • 163
    Re: Scanning sharp mxm 453
    are we talking ftp, smb, or email?
    • davebtech
      • Apr 2015
      • 175
      Scanning ftp,not to email
      • sharptech1
        • Oct 2011
        • 163
        most common problems are network scanner tool not being started or blocked by firewall or anti-virus. also ip addresses could be changing and you could try switching to computer name instead
        • davebtech
          • Apr 2015
          • 175
          [QUOTE=sharptech1;506226]most common problems are network scanner tool not being started or blocked by firewall or anti-virus. also ip addresses could be changing and you could try switching to computer name instead[/QUOTE. Thanks for input when you say network scanner tool not started what causes it not to start?
          • davebtech
            • Apr 2015
            • 175
            [QUOTE=davebtech;506229]
            also any problem firewalls or antivirus software you know of?
            • peter42
              • Jan 2012
              • 110
              Check cable:
              i often find old cat5 lines, that are certified to 333 Ghz, that is not gigabit. Printing works fine, but scanning troubles the users.
              Changing to Cat 5e or Cat 7 helps.
              greetings peter
              PS, remove Ethernet-line from machine and ping Machine adress from PC. If there is an answer, you found the problem.
              • davebtech
                • Apr 2015
                • 175
                Originally posted by peter42
                Check cable:
                greetings peter
                Thanks Peter just learning this network stuff. What causes a companies ip addresses to move around?
                • peter42
                  • Jan 2012
                  • 110
                  Often the new Iphone from Boss receives an internal used adress from WIFI.
                  He is sitting proud in his office and users are not able to print or scan.
                  Have the network admin to reserve ipspace for mobile devices
                  away from internal used ip adresses.
                  greetings peter
                  • mansart
                    • 852
                    Your Guide to the Home Network - Homenet Howto
                    Decent website for networking basics
