I was looking around for an answer to a question...
I tried setting up smb scanning to a pc with windows 10... logmein and teamviewer on it.
Smb scanning did not work...
i could ping but nothing would go through... so I just did scan to email...
funny enough... I couldn't use gmail's smtp 587 settings... I had to use aol...
anyway that was an aside...
back to the issue... I could not scan to smb but scan to email worked...
I coughed it up to logmein and teamviewer hogging the ports but I am having second thoughts...
I noticed that whenever I saw such high activity remote connections... a domain was involved...
I am thinking that its an issue with the domain...
probably something involving smb signing...
I was on a ricoh mpc 4000...
I was looking around online and found the following solution for a toshiba estudio...
Toshiba eStudio Copier/Scanner
Connect to copier/scanner using web browser. Click Administration tab, and logon use the copier's username/password.
Click Network
Click SMB Session
Click SMB Session box
In section called "SMB Signing of SMB Server", the default of "If client agrees, digital signature is done for communication" needs to be changed to "Digital signature isn't done for communication for the server"
Click Set button at top, then Save button, and the copier will reset.
My question is how would i go about dealing with this smb signing on a ricoh mpc copier... or even a kyocera task alfa...???
(keep in mind my usual work around is scan to email... )
its possible to disable smb signing for the network but no network admin would do that for a copier...
Click Network
Click SMB Session
