Ricoh MPC 4500 and 4503 WIM issues
  • jsteg1981
    • May 2016
    • 13
    Hello all!
    I am in charge of a project for a big company with over 1000 Ricoh printers. They have several printers that after an hour or so, the Ricoh must be rebooted in order to access the Web Image Monitor. Their network team points the blame at Ricoh and Ricoh says it's their network. I am wondering if anyone has ever seen this and may know what is causing it.
    When these machines need the reboot, their clients can still print, scan, fax, whatever... Everything works aside from the WIM. I don't think it is their network as I have found a location with two 4503's and one has this issue and the other does not. I am currently comparing settings between the two, but have found nothing that has made a difference.
    I appreciate any and all help!
  • copier tech
    • 8138
    Re: Ricoh MPC 4500 and 4503 WIM issues
    Originally posted by jsteg1981
    Hello all!
    What level is the firmware on? I'd start by flashing them all to the latest levels
    • ruben
      The New Guy
      • Oct 2012
      • 1203
      What is the return code the browser gives you?
      • keithxxiii
        Just a tech
        • Nov 2014
        • 468
        Try to reduce the network security level to zero...
        just a thought though.
        Aye! Cut the crap
