Connecting to WiFi
    • 37503
    #16
    Re: Connecting to WiFi
    Originally posted by Leebs14
    Can I configure a USB wifi stick on my PC to work with the wifi network then
    Unplug it and plug it into the MFP USB port? Will the USB wifi device lose its set up when I unplug it?
    You are actually configuring your PC to recognize and use the USB WIFI device. Nothing is stored on the device. The devices that a number of us have recommended are also configured by first connecting them to your computer (CAT 5 port), but with them you are configuring the device and the settings are saved on the device. Netgear N600 (WNCE 3001) can be found online for under $50.00.
    • Leebs14
      • Feb 2014
      • 457
      #17
      • Leebs14
        • Feb 2014
        • 457
        #18
        Works a treat, 5 minute set up and voila you have a wifi enabled copier!!
