Connecting to WiFi
  • Leebs14
    • Feb 2014
    • 457
    Connecting to WiFi
    Help needed!!
    Is there a generic device available which I can physically plug into a copier/printer and then connect to a customer wireless network?
    Something that's easy to use and set up and just accepts the print job sent over the wireless network and sends it down the wire to the printer?
  • NSD
    • Aug 2011
    • 44
    Re: Connecting to WiFi
    An old netgear router or accesspoint in Bridge mode does the job nicely.
    Sent from my SM-G920F using Tapatalk
      • 23008
      This is the device that I've used: http://downloads.linksys.com/downloa..._QI_NC-WEB.pdf
      There are about a million other devices that do about the same thing. =^..^=
      • Leebs14
        • Feb 2014
        • 457
        Thanks guys, I wondered in this day and age there was a simple plug and play device
          • 23008
          I wouldn't exactly call it Plug & Play. There is some setup required, but it's not overly complex. You can run the disk or do it manually. I've done it both ways.
          • Ben Around
            • Apr 2012
            • 151
            Use a wifi range extender. They work great and are available at office depot, best buy etc. for about 60 bucks. Make sure it has an ethernet connector to plug the MFP in though.
            Here is an example:
            Netgear N300 Wi Fi Range Extender by Office Depot & OfficeMax
            • NeoMatrix
              Senior Tech.
              • 3513
              Any wireless modem/router should do the job. Something like Netgear wireless router, they come in all shapes and sizes. If you want USB to Ethernet HP (Hewlett Package) had a USB to Ethernet conversion unit. It's been a while since I've seen them for sale though.
              "www.netgear.com.au\home\products\networking\modem-routers\d1500.aspx?cid=gwmng"
              D1500 | Modem Routers | Networking | Home | NETGEAR
                • 37508
                Netgear WNCE 3001 or predecessor WNCE 2001. They are small, once programmed from a computer for the wifi network will connect to the CAT5 port on your MFP, can also be connected to a small work group switch to connect multiple non-wifi enabled device. to a wireless network.
                • copier tech
                  • 8164
                  I've been using the Apple Airport express, small, cheap & easy to setup, especially if you have an IOS device like an iPhone etc.
                  Mac - AirPort Express - Apple (UK)
                  • msquared840@gmail.com
                    • Jun 2015
                    • 29
                    get a USB-Wireless Print server or USB-Ethernet print server.
                    but if you plan connect using USB-Wireless print server, make sure that the wireless signal between your printer and router is strong (at least 3bars)
                    • NSD
                      • Aug 2011
                      • 44
                      Another option would be a powerline adaptor. Then yoy could connect the mfd direct to the wifi router.
                      • peter42
                        • Jan 2012
                        • 110
                        Place the mfp near customers router.
                        connect the LAN-wire from MFP to router.
                        Amazingly, any Network atached devices over WIFI can see and use MFP, if drivers are installed
                        and MFP is correct configured.
                        greetings peter
                        PS: If they need a mobile MFP, that can be moved from place to place, garage to office, tell them, thats no go for a long live of machine.
                          • 37508
                          Re: Place the mfp near customers router.
                          This thread is about what to do when there is no wired connection where the customer wants the MFP and they do not want anyone to run cable there because they are primary wireless. More often that not, the router is located in a wiring closet or server room that only IT and a few other people have access to.
                          • Leebs14
                            • Feb 2014
                            • 457
                            Can I configure a USB wifi stick on my PC to work with the wifi network then
                            Unplug it and plug it into the MFP USB port? Will the USB wifi device lose its set up when I unplug it?
                            • emujo
                              • Jun 2009
                              • 3009
                              A USB wireless will not work on the MFP. Unless you have the wireless accessory kit built into the MFP, you must cable the MFP somewhere. That somewhere can be a network jack, directly to the router, or a wireless access point. The WAP is pretty convenient, all you need to do is put the WAP on the same wireless network the users are on. Once configured you cable the MFP to the WAP and it should hand out an address, or you can assign a static. Any users on the same wireless network can download the print driver and start printing. Emujo
