New Mac OS
  • richs
    • Nov 2008
    • 262
    New Mac OS
    I have had no luck connecting the newer macs to scan.I have tried SMB and FTP with the same results.Has anyone had any luck.​I do work on several brands ....mostly Oki and Kyocera.....same problem.
  • peter42
    • Jan 2012
    • 110
    Re: New Mac OS
    add a new user to Mac: name is scan, pass is scan.
    read this. 10.7: Enable the FTP server - Mac OS X Hints
    apple has disabled by default the ftp in his OS.
    follow the hints and the scans are landing in the homedir of user scan.
    • qbert69
      • Mar 2013
      • 1152
      Re: New Mac OS
      Apple's implementation of SMB is total crap!
      I've had fairly good luck installing and configuring SMBUp:
      SMBUp – eduo.info
      GOOD LUCK!
      REACH FOR THE STARS!!!
      Konica Minolta Planetariums!
      • Stevehuk
        • Aug 2016
        • 5
        Re: New Mac OS
        SMB
        Do the devices have any NTLM settings? (Usually under Network configurations)
        If so then try each option. I only work on Bizhubs which default to NTLMv1 but will fail when scanning to Mac 10.7 or higher.
        Usually all it takes to fix is to change NTLM to v1/v2 but if you can't marry up the authentication protocol to your Mac then you might have to to go with FTP.
        What steps have you taken for SMB Scanning?
        SteveH
          • 37521
          Re: New Mac OS
          Maybe this link will help.
          Re-Enabling SMB/Samba access With Mac OS X 10.7 and 10.8 | FAQ | Customer Services | Website | OPPO Digital UK
