Scan to server 2016
  • Leebs14
    • Feb 2014
    • 457
    Scan to server 2016
    I came across this today for the very first time, I have a MX3111 which worked fine when scanning to network folder on server 2012, but now keeps saying authentication has failed on 2016??
    Anyone??
  • Cipher
    It's not easy being green
    • May 2006
    • 1309
    Re: Scan to server 2016
    I would imagine scanning to Server 2016 would require the same level of compatibillity as scanning to Windows 10.
    • Leebs14
      • Feb 2014
      • 457
      Machine worked perfectly on windows server 2012??
      • Cipher
        • May 2006
        • 1309
        Server 2012 / R2 is based on Windows 8 / 8.1
        The version of SMB / Samba used is older.
        In add and remove programs / windows features you may be able to enable "SMB 1.0/CIFS File Sharing Support" as a work around.
        But check for a firmware update for your MFD first.
          • 37517
          Server 2012 or Server 2012 R2? Server 2016 is based on Server 2012 R2 with a few cosmetics changes. Functionality is the same as a fully up to date, all patches applied, Server 2012 R2. There was an update a while back that caused some problems with scan to folder. Scan to a Server 2012 R2 on a different subnet will not work unless domain name of the scanner is correct. Scan to IP address will not work, worked before the update. Scan to netbios name will not work unless first DNS is the primary domain DNS. Domain DNS will reject name search from any device that is not part of the domain, requesting device not recognized.
          • Leebs14
            • Feb 2014
            • 457
            Been in today and updated firmware on machine to latest level and their IT are going to try setting it up this afternoon, they have a MX2640 upstairs which scans ok.
