Hi all we have just installed 3 x km c308 to replace currant richo machines we have used a 3rd party to install equitrac . Customer had thus running previously on richos but we have an issue where from clients pc they is no prompt for log in when print job sent ..all print jobs can be seen and but cannot release them as there is no prompt to where they have come from all tabs are correct from client express software....any info much appreciated
Equitrac
Tags: None
Re: Equitrac
Nothing you can do from a copier perspective to get this to work.
Whoever set up and maintains the Equitrac solution needs to be involved.
I'm not sure, but the licensing may very well be different between the 2 makes of MFPs, and it's highly unlikely that the new license would be at no cost.“I think you should treat good friends like a fine wine. That’s why I keep mine locked up in the basement.” - Tim Hawkins -
Re: Equitrac
Hi thanks for the reply, equitrak are installing there software but they are struggling to recreate the log in prompt at the workstations , as this reflects on our side we are trying to find a solution.we have loaded the client express to workstations and the only thing we are missing is the prompt... many thanksComment
Re: Equitrac
While you can edit the Ricoh driver for pop-ups, the Equitrac pop-up is its own, unrelated beast.
The Equitrac pop-up is mostly used for client codes, matter codes, etc... The data that gets put into it ends up in the Equitrac reporting portion of the application.
While it could be that the now displaced Ricoh machines had their drivers edited, I have a hunch they did not, at least in this case.“I think you should treat good friends like a fine wine. That’s why I keep mine locked up in the basement.” - Tim HawkinsComment
Re: Equitrac
Check out this link from the Nuance / Equitrac knowledge base:
Pop-up Notification Dialog Box Is Missing on the Workstation ClientLast edited by KenB; 12-24-2016, 02:18 AM.“I think you should treat good friends like a fine wine. That’s why I keep mine locked up in the basement.” - Tim HawkinsComment
