Equitrac
  • steve schofield
    • May 2010
    • 117
    Equitrac
    Hi all we have just installed 3 x km c308 to replace currant richo machines we have used a 3rd party to install equitrac . Customer had thus running previously on richos but we have an issue where from clients pc they is no prompt for log in when print job sent ..all print jobs can be seen and but cannot release them as there is no prompt to where they have come from all tabs are correct from client express software....any info much appreciated
  • KenB
    Geek Extraordinaire
    • Dec 2007
    • 3944
    Re: Equitrac
    Nothing you can do from a copier perspective to get this to work.
    Whoever set up and maintains the Equitrac solution needs to be involved.
    I'm not sure, but the licensing may very well be different between the 2 makes of MFPs, and it's highly unlikely that the new license would be at no cost.
    • steve schofield
      • May 2010
      • 117
      Re: Equitrac
      Hi thanks for the reply, equitrak are installing there software but they are struggling to recreate the log in prompt at the workstations , as this reflects on our side we are trying to find a solution.we have loaded the client express to workstations and the only thing we are missing is the prompt... many thanks
        • 37510
        Re: Equitrac
        With Ricoh, the pop-up box for user code is enabled by editing the printer driver using either Ricoh's Print Driver Editor or its replacement Printer Driver Packager NX. Check with KM to get their equivalent.
        • KenB
          Geek Extraordinaire
          • Dec 2007
          • 3944
          Re: Equitrac
          Hi, SlimSlob,
          While you can edit the Ricoh driver for pop-ups, the Equitrac pop-up is its own, unrelated beast.
          The Equitrac pop-up is mostly used for client codes, matter codes, etc... The data that gets put into it ends up in the Equitrac reporting portion of the application.
          While it could be that the now displaced Ricoh machines had their drivers edited, I have a hunch they did not, at least in this case.
          • KenB
            Geek Extraordinaire
            • Dec 2007
            • 3944
            Re: Equitrac
            Check out this link from the Nuance / Equitrac knowledge base:
            Pop-up Notification Dialog Box Is Missing on the Workstation Client
