Default Printer ERROR
Tags: None
Re: Default Printer ERROR
It might be pertinent to know what manufacturer and model of printer, what OS your PC or Mac are running, what version of the driver you installed, and if you're using the WSD port. =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^= -
Originally posted by alamsandhuuser credentials issue create another user and install via that user it will work
Just go into the registry and delete the following key:
HKLM\SYSTEM\CurrentControlSet\Control\Print\Printe rs\printername\CopyFiles
Where printername is the name of the printer you're trying to add.
If the printer is shared from a server this will have to be done from the print server.
I've seen this quite a bit with HP printers. Just another instance of their poor driver design.Comment
