smb v1 and wanna cry
  • tonerhead
    • Sep 2009
    • 582
    Sorry if I am riding on another post, but I am curious what people are experiencing with this malware. For the most part it seems SMB scanning is stopping.
    I guess I need to get caught up better on this malware. What have you been experiencing? Any cures yet. I guess everyone is waiting on firmware.
    I've proved mathematics wrong. 1 + 1 doesn't always equal 2.........
    Especially when it comes to sex
  • Codex
    • May 2008
    • 701
    Re: smb v1 and wanna cry
    I think the smallest problem is the scanning.........if all your files are encrypted.....
    Memento Audere Semper
    • ricmartinho
      • 142
      Hi there!
      We have a customer with this problem that found a thread (https://community.spiceworks.com/top...-really?page=1) and got SMB scanning on Ricoh machines solved.
      They changed the SMB port from 139 to 445. This can be done through telnet.
      msh> smb client port
      -Displays the current setting
      msh> smb client port #
      -Change port number
      Setting value
      Result
      139 (default)
      SMB client uses port 139 port
      445
      SMB client uses port 445 port
      • tonerhead
        • Sep 2009
        • 582
        Yup, I think everyone realizes this, however, we have customers losing smb scanning because they are trying to prevent infection by shutting down SMBv1.
        • Codex
          • May 2008
          • 701
          I think the best solution is to update your system, Microsoft released a patch even for Xp.... If your system is up to date you can turn on smb
          Inviato dal mio SM-G935F utilizzando Tapatalk
          • emujo2
            • Mar 2017
            • 1579
            Newer KMs can turn off SMB ver1 and only use v2/3..This is a softswitch change and must be done through service mode though. Emujo
            • MattL
              • Apr 2012
              • 97
              Once you are patched you can then turn SMB1 back on. That is what one of my IT support companies is doing as too many things stop working so as they are patched there is no issue.
              • habik
                • 2013
                Hi Emujo2,
                Is there a SSW for the older series a.e. 554e's? Haven't found anything in Service Manual?
                Many Thanks for any reply.
                Cheers
                habik
                Firmwares HERE
                • mbcruzin
                  • Aug 2013
                  • 142
                  been having the same issue on a sharp mxm316, and , mxm356. An IT friend found this link to set up LDAP for athentication.
                  Hope this helps
