Ricoh Mp C4202 address book issue
    • 29787
    I can upload a new address and show's on web interface
    But not on machine panel????
  • COPIERMAN
    • Jun 2009
    • 559
    Re: Ricoh Mp C4202 address book issue
    check in address book and make sure is info in the key display if blank possible wont show up on copier.
    • ayeright
      • Feb 2011
      • 74
      You have set the "Add to freq" radio button in the address book entries? If not, the address's can only be seen from the lookup tabs.
        • 37240
        Do you mean not in User Tools - System Settings - Administrator Tools - Address Book Management or do you mean in either the fax or scanning function?
        In order to show in fax function, there must be an entry in the fax destination field. The same is true for entries for scan to folder and scan to email.
          • 29787
          Address using web interface upload and shows but not on machine
            • 37240
            Does not show where on the machine?
              • 29787
              in address book on panel of machine
              • COPIERMAN
                • Jun 2009
                • 559
                create a user from the op panel does and put in a fax number does it show up in fax mode.
                  • 37240
                  OK, now can you tell us if that is in Address Book Management in user tools or is it in the fax function screen or the scan function screen.
                    • 29787
                    scan to email
                      • 37240
                      scan to email
                      Was valid email address entered in the correct place in the address book entry?
                      • keithxxiii
                        Just a tech
                        • Nov 2014
                        • 468
                        You have to be sure that "Key Display" is filled in.
                        Aye! Cut the crap
