Can't scan to email using a Konica Minolta using gmail business
  • printerpurgatory
    • Jan 2018
    • 23
    The question is pretty much explained in the title and I'm sure you have seen this question before and I've read a countless number of posts about this issue but still I can't get this to work. I'm pretty sure it's an authentication issue. I've turned on the error code display but am only getting error code 107 which isn't very helpful. If anyone can give me some suggestions to try or help of any kind it will be greatly appreciated.
    My settings are as follows:
    Network--->Email Setting--->Email TX (SMTP)
    Scan to email ---> ON
    SMTP Server Address ----> using IP instead of hostname
    Use SSL/TLS ----> SMTP over SSL port 465
    Connection Timeout ----> 120
    Admin email address printer@domain.com
    Device Email address printer@domain.com
    SMTP Authentication---> LOGIN
    User ID ----->
    printer@domain.com
    Domain name ----> blank
    Machine Setting
    administrator email address ---> printer@domain.com
    machine address ----> printer@domain.com
    Security ----> PKI Settings ----> SSL settings
    Mode using SSL/TLS --- > Admin mode usermode
    Encryption Strength --- > AES256,3DES-168,RC4-128
    SSL/TLS Version Setting
    SSLv3
    TLSv1.0
    TLSv1.1
    TLSv1.2
  • rthonpm
    • Aug 2007
    • 2859
    Re: Can't scan to email using a Konica Minolta using gmail business
    SMTP error 107 is an SSL protocol error. What happens if you change the SSL/TLS settings to only use TLS? You may also want to use Port 587, which is for TLS. Also check firmware to make sure that you're not missing out on newer settings, and take a look at this from Google: Send email from a printer, scanner, or app - G Suite Administrator Help
    For a major SMTP server, you always want to use the hostname since there are likely multiple IP's available for the same name so that you don't run into an overloaded server. To do that, just make sure you have a valid DNS server set, either an internal one that resolves to an external server, or just one like Google's public DNS server or 8.8.8.8
      • 30293
      Use the Gmail SMTP Server
      If you connect using SSL or TLS, you can send mail to anyone with smtp.gmail.com.
      Note: Before you start the configuration, make sure that Less secure apps is enabled for the desired account.
      Connect to smtp.gmail.com on port 465, if you’re using SSL. (Connect on port 587 if you’re using TLS.)
      Sign in with a Google username and password for authentication to connect with SSL or TLS.
      • printerpurgatory
        • Jan 2018
        • 23
        I actually figured this out a few weeks ago, thanks for the reply though. As far as I know the model of printer that I have needs some weird tweaks and firmware upgrades to get this functionality to work with gmail so ended up using mandrillapp instead and it works fine.
          • 37529
          Error code 197 is a failure to connect. See Konica/Minolta error code trouble shooting Troubleshooting
          See the following Google support document for proper setup of scan to gmail. Send email from a printer, scanner, or app - G Suite Administrator Help
          • kingarthur
            • 1367
            Device Email address printer@domain.com.... this could be where you're getting a problem for gmail you leave the device email address empty, instead you put the email address where the device name is, been caught a few times until i learned
            • leprosydog777
              • Jan 2018
              • 33
              Hello quick question what model because the non e models there is special firmware for gmail to work
                • 37529
                He is indicating that an email address for the printer has been setup on the customer's google apps domain. printer@domain.com is a generic expression to use when you do not want to publish a customer's actual information in a public forum.
                • kingarthur
                  • 1367
                  I'm not saying the email address is wrong...I'm saying that when setting up gmail, the email address isn't input in the usual/expected place, but you put the email address where the device name is....and leave the machine email address box empty
