Kyocera and WSD printing
  • Brianneoe
    • May 2015
    • 318
    My setup department have been turning off WSD on my Ricoh's but have left it alone on my Kyocera's because it never had caused us a problem until this week. I had to follow up a technician after he installed the print drivers on 10 workstations and found that the windows 10 boxes were using a "Kyocera XPS" drivers. We install the KX drivers using TCP as SOP. We never had a windows 10 box delete the driver and reinstall XPS. As anyone who deals with the Ricoh product knows,windows 10 will install a "Ricoh Class"driver using WSD if the WSD protocol is left on.
    The Kyocera XPS driver wasn't labeled "Kyocera Class"driver but as Kyocera XPS.XPS is Microsoft version of postscript that is needed for certain apps but as a every day driver it is not recommend by Kyocera.
    My main concern is if there was a update in Microsoft's newer OS's that will now delete the previous KX drivers and replace them with the XPS driver.
    Its my hope that the tech that I followed up was just having a bad day and that I will now not have a bunch of Kyocera customers calling me with print job problems.
    • 22997
    Re: Kyocera and WSD printing
    WSD is just as troublesome on Kyocera, Toshiba, Lexmark, and every other manufacturer I see. =^..^=
      • 29871
      No WSD driver or Port Period
      • Brianneoe
        • May 2015
        • 318
        Thanks for the input all, WSD is not the way to go but I never had to bother to turn it off on a Kyocera. It was like the windows boxes didn't recognize the Kyoceras' on the network because windows didn't have a Kyocera driver to link with the WSD protocol.So far this had happen on a 01 series machines and Im sure the newer 02 series will also self install.
        Can anyone confirm or shed more light on what driver the windows 10 machines will automatically configure with WSD turned on?
        So far it looks like its using the XPS driver and if that is the case I will be chasing around customers all over my territory reinstalling drivers and turning off WSD.
          • 22997
          Originally posted by Brianneoe
          ... So far it looks like its using the XPS driver and if that is the case I will be chasing around customers all over my territory reinstalling drivers and turning off WSD.
          That's what we do. =^..^=
          • kuby
            • Oct 2007
            • 1395
            Yea we turn it off whenever we install a printer/copier.
            • GeneOR95
              • Feb 2018
              • 161
              We also turn it off at setup. We have found that if the end user has allowed windows to manage their printers, as soon as a windows update hits, windows uses WSD to replace the default driver and screws the pooch.
              • hdmr
                Helpdesk Engineer
                • Feb 2013
                • 51
                Always see WSD Ports causing issue on the Ricoh products - never thought to switch the feature of from a device level before.
                Thanks for info.
                • savedR
                  • Nov 2015
                  • 8
                  Hey all,
                  Sorry to necro this thread, but I just had to turn off WSD on a FS-C2526, and it took me a while to find it. So I figured I'd post where it was here, so the next tech doesn't have to search!
                  I got into Command Center (web UI), then logged in as Admin. Then I clicked Basic tab (blue), under Security, mouse over Device Security and choose Network Security, then scroll to the end of the page and there are 4 switches for WSD, for print, scan, enhanced WSD, and enhanced WSD over SSL, all of which I turned off. Then I restarted the printer, and the Win10 PC I was on didn't find it, so it should be good.
                  As an aside, one of the Windows Updates that came through this year also seems to automatically add another printer copy if IPP settings are left on now, just like WSD. I've mainly seen it happen with Canons, but I bet it does for other brands too.
                    Had a Ricoh im3000 that I let Windows10 install drivers for. I printed to it and the red light on the Ricoh started flashing, I walked over to it pressed printer and it said use alternative paper. I knew what had happened instantly the driver had somehow sent it a letter size document when we use a4, a3. Took a brief look at the printer driver all seemed ok then deleted it and used the real Ricoh driver all was good after that.
                      • 29871
                      No Period. Do I disable No. Install the KX driver and configure.
                      • Vincent128
                        • Sep 2015
                        • 346
                        On the Toshibas we used to turn it off but then found out that it breaks mobile printing from 'Droid ... mostly though the windows deleting printers and installing WSD and using a junk driver can be fixed by unchecking 'let windows manage my default printer' ... have not had any more issues with WSD.
                          I turn off WSD on everything I touch.
                          • Blizzoo
                            • Aug 2013
                            • 605
                            Indeed the scanning app Toshiba Ebridge Print and Capture won't work if WSD for Print and Scan is disabled. If the customer is using only iPhones and don't need to scan from MFP to the phone they can use AirPrint and turn off WSD.
                            • Brianneoe
                              • May 2015
                              • 318
                              Originally posted by savedR
                              Hey all,
                              I started to disable IPP also on my Ricoh units for the same reasons you stated. The only problem so far is that it also breaks Airprint.
