Kyocera products scan to email no SSL
  • toddanderson
    • Dec 2005
    • 233
    #16
    SMTP with free account
    Does
    Gawab has smpt available for a free account, it looks like you can only use
    smtp with the paid account ?
    Originally posted by jneezy2008
    I recently found Gawab.com Web-based Email email POP3 SMTP IMAP SMS. You just register for a free account and use the SMTP settings to setup scan to email. It's 100% free. You can use SSL if you want, it's optional. As long as the account is kept active scan to email will work forever. There's nothing to install or setup on a customer's PC. I've tested Gawab.com Web-based Email email POP3 SMTP IMAP SMS on several of our showroom MFPs and it has worked everytime.
    • fausto1981
      IT Technician
      • Dec 2007
      • 146
      #17
      Originally posted by Jules Winfield
      I've used Argosoft in the past and it works great for most scenarios. Recently I discovered a new mail server app that has a free version like Argosoft, but has way more features. I needed something that could import a list of user accounts from a CSV file (something Argosoft can't do) and I found this:
      DeskNow
      DeskNow is Awesome...
      • jfultz
        #18
        We have a customer that has a Falcon III and a Konica Minolta Color (C353 maybe) and they use Google for email. We were able to get the Konica to scan, but were unable to get the Kyocera to scan (did not try turning on SSL under "Advanced --> Secure Protocols --> SSL". I figured that was just for the web browser, makes sense that it would turn SSL on for the entire machine though. I'll have to try that next time.
        Also just FYI I have run into alot on ISP's lately that are blocking port 25. Easiest way to test "telnet servername/IP 25" if it won't connect then port 25 is probably being blocked.
