Need Support
  • mdfurqan2012
    • 194
    Need Support
    Dear all
    I have Ricoh Pro8120s with external Fiery Controller EB-32.
    I am facing some difficulty in printing. I have to print multiple files of MS word and PDF format sent to printer in sequence, we enable duplex "open to left" by default by that the files contains more than one page print in duplex. I am facing files contains single also pass from duplex by which machine speed reduced 50%. I observed that all single page files shows 2 pages on machine's panel.Even if I print windows test page it pass through duplex.
    when we disable duplex same files shows single page on machine's panel and not pass through duplex but i am unable to print files more than one page in duplex mode.
    Kindly guide me.
    I am waiting for your response.
    Furqan
    Re: Need Support
    Originally posted by mdfurqan2012
    Dear all
    Kindly guide me.
    Furqan
    well you mentioned Word and PDF... and duplex
    1) duplex will slow MOST machines down
    2) didn't mention SIZE of the FILES
    3) have you checked the PROPERTIES of the file VS the settings on the machine/software
    4) how are you connecting the PC/MAC to the Fiery and to the machine?
    5) are firmware files up to date on machine and Fiery?
    really..... if you need help you need to provide more information.
    • mdfurqan2012
      • 194
      Re: Need Support
      [QUOTE=Phil B.;686602]well you mentioned Word and PDF... and duplex
      1) duplex will slow MOST machines down.
      If slow down for duplex printing of more than one page is ok. I said if print singal page file will also pass through duplex means unnecessary duplex slows down machine.
      Not more than 8 pages
      Yes
      By network
      Yes.
      Kindly guide me
        Re: Need Support
        [QUOTE=mdfurqan2012;686882]
        Yes
        By network
        Yes.
        Kindly guide me
        not # of PAGES but SIZE (MB) of the files.
        you have duplex on as default... TURN IT OFF
        clearly you aren't a tech. HIRE ONE.
        • mdfurqan2012
          • 194
          Re: Need Support
          [QUOTE=Phil B.;686886]
          Maximum file size is 1MB
          When we trun off duplex machine speed becomes normal but issue is that we have to print files of more than one page in duplex which will not done when we trun off duplex.
          I am a tech who maintain ricoh's high end machines since last 15years. Currently I run same printing jobs on Ricoh pro1357ex perfectly now we add Ricoh pro8120s and facing this issue.
            • 23008
            Re: Need Support
            Auto duplex means that all printed pages pass twice, regardless of it's 1 image or more. That's the essence of it. =^..^=
              Re: Need Support
              yeah thought he would grasp that from my post about PROPERTIES... guess not
              • mdfurqan2012
                • 194
                Re: Need Support
                Dear
                It works on pro1357ex that singal page file not pass through duplex and files more than one page print in duplex. Although duplex is set to "open to left" for all files.
                Pro 1357ex have it's own built in print controller.
                Pro 8120s have external fiery controller.
                  • 37515
                  Re: Need Support
                  Dear
                  It sounds to me like you have not been formally trained on either the Pro8120, Fiery, or both.
