IPv6 error
  • Gordana
    IPv6 error
    Hi!
    We have Konica Minolta 554 network printer, which is working fine over IPv4. But trying to set a static IPv6 address we get Gateway Address Unsuitable value error. What could be wrong? How can we get the right Gateway?
    Thanks for all help.
    • 8165
    Re: IPv6 error
    Originally posted by Gordana
    Hi!
    Why do you need to use IPV6 ? Turn it off & use IPV4.
    • Gordana
      Re: IPv6 error
      We have a new wifi Eduroam network that works only over IPv6. So if I want to use that fast network on my laptop I need the printer on IPv6.
      • qbert69
        • Mar 2013
        • 1152
        Re: IPv6 error
        I suggest you pose your Question to Eduroam as it is the networking device causing the "problem"!!! If IPv6 on the MFP is set to DHCP then you should be able to map a printing path to the MFP with hostname regardless of what the IP address is. [emoji41]
        Sent from my SM-N950U1 using Tapatalk
        REACH FOR THE STARS!!!
        Konica Minolta Planetariums!
