Ricoh MP4500 don“t print with "Deleting file" message
  • Fogonazo
    • Jul 2011
    • 15
    Hi
    I have a Ricoh MP4500 with the following trouble.
    When send a printout, the data reception indicator flashes, "Printing" appears on the display and a couple of seconds later "Deleting file"
    • 37481
      • 30198
      • Fogonazo
        • Jul 2011
        • 15
        Typical symptom when the user code is missing or incorrect.
        The machine did not have a user code.
        Also do the procedure SP 5-404 and delete all the accounts SP 5-846-50, but it did not work
        Thanks for your reply.
        Are you printing from a Mac? Needs PS option
        It is not a Mac system, but it also has PS
          • 30198
          What print driver? load PCL 6 driver print using ipaddress and raw 9100 port
          • Fogonazo
            • Jul 2011
            • 15
            It is configured by: TCP / IP
            Protocol: RAW
            Port: 9100
            Thanks for answering
            Is there any way to take the printer to original factory settings?
              • 30198
              Protocol: RAW
              Port: 9100
              Setup a new printer driver and test , if it still wont print recheck the authentication and codes are OFF .. Another question ping device with machine off
              if you get a reply from that ipaddress you have a another device with the same ipaddress on the network
              • keithxxiii
                Just a tech
                • Nov 2014
                • 468
                Aye! Cut the crap
                • copier tech
                  • 8143
                  Originally posted by keithxxiii
                  Network Security Level?
                  Access Control enabled?
                  Enhanced External Charge Unit Management (printer ON)?
                  Is Virtual Printer ON?
                  Do an NCS reset (SP 5801-011)
                  As suggested above i'd do a network reset.
                  Also have you tried printing from your laptop bypassing the network?
                  And updating the firmware would also be a good idea, possibly corrupt fw.
                  • Fogonazo
                    • Jul 2011
                    • 15
                    Tests:SP 5801-011 Result: None
                    Change equipment to an exclusive network: None
                    Set up a new printer driver: None
                    Control equipment from another PC: None
                    • jonhiker
                      • 661
                      • Fogonazo
                        • Jul 2011
                        • 15
                        Originally posted by jonhiker
                        Have you checked the error log on the copier for more information?
                        Press the button on the op panel for "printer" and check there to see if there is an error.
                        The print error log is empty.
                        Thanks for comment
                          • 37481
                          Thanks for comment
                          Al printer logs are deleted when power is cycled.
                          • qbert69
                            • Mar 2013
                            • 1152
                            Hi
                            If customer is trying to print a webpage with rolling/ changing graphics, ricoh doesn't know how to interpret that information. Will hang every single time!!! Customer needs to copy & paste to another document or save as flat pdf & print. Bullzip is the answer. [emoji41]
                            Sent from my SM-N950U1 using Tapatalk
                            REACH FOR THE STARS!!!
                            Konica Minolta Planetariums!
                            • Fogonazo
                              • Jul 2011
                              • 15
                              This is not the case, the windows test page is not printed.
