Windows 7 machines
  • mo0651
    • 1054
    Windows 7 machines
    Anybody have a work around for the latest Microsoft update that has taken out SMB to a folder on the desktop of Windows 7 machines? Just started happening around here.
    None of the old fixes are working. Getting "Server connect errors", and "forward TX errors" on Konica Minolta machines.
  • NeoMatrix
    Senior Tech.
    • 3513
    Re: Windows 7 machines
    Try the following thread....
    http://www.copytechnet.com/forums/ri...tml#post720983
    hhttp://www.copytechnet.com/forums/ricoh-savin-gestetner-lanier/135496-scan-folder-pc-ok-lap-top-failed.html#post720983
    HTH
    • Hansoon
      • Sep 2007
      • 3402
      To my opinion is Scan-FTP the solution. Never ever have any scan problems with my customers.
      Quick 'n Easy FTP Server Lite
      + Static IP-Adresses for the workstation with the scan target.
      Hans
      • Synthohol
        Certified Konica Expert
        • 5913
        Originally posted by Synthohol
        M$ squeezed out 2 patches that may stop SMB scanning back on the 8th.
        have a read.
        Network issues with updates KB4480970 and KB4480960 | Born's Tech and Windows World
        • tsbservice
          Field tech
          • 8077
          There is new update from M$ KB4487345 to cope with this issue.
          • rthonpm
            • Aug 2007
            • 2860
            The issue with the two Microsoft patches isn't so much an SMB issue as it is an authentication issue.
            Make sure that you're connecting to shares on the MFP using the actual hostname as opposed to IP address, and if you're using a local account to authenticate to the share, make sure it doesn't have administrator rights on the server/computer hosting the share.
            So far, we've seen this issue with a few workgroup based customers, but our domain customers have been spared.
            Here's the link to the update to fix the issue: Microsoft Update Catalog
            • mo0651
              • 1054
              The Microsoft update KB4487345 worked for me today. Heading out tomorrow for MORE Microsoft induced FUN !!
