print volume reporting solution for USB connected Ricoh printers
  • Brianneoe
    • May 2015
    • 318
    Can anyone point me in the right direction on a client\server solution that collects meter counts on USB connected Ricoh printers. If it also collects the counts on networked machines all the better. The account that I need this for has 50 standalone USB connected printers along with 15 networked MFPs. Right now they are using the latest version of Copy Track to bill out their clients (law firm)but I believe the Copy Track product won't give me a total per machine printer\MFP meter read.
    If anyone is using Copy Track and knows that this solution can perform this task please let me know..
    Thanks in advance for any help you can provide.
    • 23002
    Re: print volume reporting solution for USB connected Ricoh printers
    Printfleet has a utility that installs on the local PC to relay counts from USB printers. =^..^=
    • qbert69
      • Mar 2013
      • 1152
      USB doesn't play too nicely with Printfleet....Printfleet uses SNMP to query machines on the ethernet network of which SNMP is a protocol of and gives complete machine statistics. [emoji41]
      Sent from my SM-N950U1 using Tapatalk
      REACH FOR THE STARS!!!
      Konica Minolta Planetariums!
      • Kimi
        • Feb 2018
        • 105
        Netaphor Site Audit will do this.
        • qbert69
          • Mar 2013
          • 1152
          How does it do a complete query through USB???[emoji848]
          • Kimi
            • Feb 2018
            • 105
            • qbert69
              • Mar 2013
              • 1152
              So how much "deep information" may be obtained such as machine error codes???[emoji848]
              • Kimi
                • Feb 2018
                • 105
                I've never done it but see attached.
                • tsbservice
                  Field tech
                  • 8001
                  No way that USB(locally) connected printers will report all that info. We use Printfleet, but never attempted to connect local printer.
                  Author mentioned he needs meter readings, that may be the case with this software or others like Printfleet.
                  • Kimi
                    • Feb 2018
                    • 105
                    OP should download Site Audit and get a trial license and test how well it works
                    • Brianneoe
                      • May 2015
                      • 318
                      Thanks to all for your input! If I do find something that works I will post.
                      Thanks again All
